Line capping in Map Finisher is refusing to do Flat capping !!
Hi, I am finding that the way lines are capped has changed. I used to to use flat line capping for bridges in the CadScript symbology but since we moved to Map Finishing it does not seem to do that any more only gives square caps. Has anybody else found this and is there an answer ? I tried using the Line caps tool in microstation to individually assign caps to lines. Not the ideal way to go !! As you can see the Flat and the Square (or Normal) come out the same. The middle picture shows how the end vertex is drawn and I want the line to end there but it causes problems when the line is above a curve. Any  help or a work around would welcome.
Printed versionmicrostation versionCadScript Line Caps tool
