I recently switched from Bentley Map Enterprise V8i to OpenCities Map Enterprise and I'm no-longer able to apply thematic height display to the point clouds. it worked fine in V8i, but using the same display settings and the same POD files in OpenCities results in an all black point cloud. I
I've tried several changes to the display settings to try and make it work but I can't. Any help would be appreciated.
Thanks!
Brandy,
This problem was reported earlier and is on-target to be fixed in the next platform release, currently scheduled for the August time-frame.
In the meantime, it is possible to install both versions of Map Enterprise on the same computer -- Map Enterprise V8i (SELECTseries 10) and the Map Enterprise CONNECT edition. They use the same license and it will not generate over-usage even if both run simultaneously on the same computer.
If you don't have the installation package for Map V8i, you can download it from the Bentley Software Downloads center. Clear & apply the Filters accordingly
