Hi, I am using Bentley MicroStation and Map. I am creating some PDFs from maps I have drawn. The PDFs are created ok however, unlike other PDFs from other programs e.g. Adobe Illustrator, when one opens the Illustrator Document Properties (even though the map looks good) in the new MicroStation PDF it does not show the fonts that I have used, it just shows Times Roman but no mention of Dingbats, Arial Bold, Morse Font etc. that are used in the file. I have checked the printer configuration everything seems to be ok other than there is nothing showing in the Font Maps Tab.
tabh,
We don’t embed the font names into the generated .pdf file generated by a power platform application. Normally this is what you will see
Is this the results you see in the Document Properties?
Hi Dan, again thank you for the information. I am seeing exactly what your 'screen shot' is showing. I was obviously trying to compare two different entities and thought they would match (Pdfs through Distiller v Bentley PDFs), just thought I was missing something! Glad you have put me right and that I am not missing the obvious. Regards Tony
