I am using PowerGEOPAK 8.11.09.918 in a fairly blank DGN file. I activate Bentley Map, which appears to work fine. But when I try to open the Map Manager, it doesn't open on my screen. I can go to the menu item "Window" and I see it as an option (7 Map Manager), but when I click it, nothing appears. I also see in the message center that it says "GEOMAPMAN is already loaded".
Any ideas on how to get the Map Manager to appear? I just tried to reinstall PowerGEOPAK with no luck.
Thanks,Ken
Hi Ken, I never see this before, but I would suggest deleting some cache and temporary preferences folder. It could resolve unwanted behavior. Go to "C:\Users\user.name\AppData\Local\Bentley\product.name\8.11\" you could find "Prefs" folder. Clean this folder to reset UI dialog positioning.
I hope that helps. Sebastien Lefrancois
