How to enable v8i Task theme as the button is greyed out? Documentation is misleading.
The V8i Task Navigation toolbox Will be available in Map CONNECT Update 6 when you enable the "Display V8i UI" Technology Preview component during installation.
So it is not yet available? Any feature enabling tokens?
The functionality will be available in the Update 6 version, which is in the final stages of delivery (June 2020).
During the installation process, you will need to choose the Configure option, then select the "Display V8i mode UI" item from the Technology Preview list.
Answer Verified By: Oto
