I have a problem / question.After installing the product, the Tasks are displayed by default as follows:
The menu shows functions related to handling, measurement, enclosure, etc.
Sometimes the function menu changes to offer view controls
I'm not doing this consciously. I'll probably click on something and that will happen, but I don't know what. I couldn't figure out when it would happen and especially how to bring it back. Once that happens, I can't return to the original feature menu.The only solution I've come up with is to rewrite the system dgnlib (MapPowerView.dgnlib), which will fix it again.
I wonder if it is possible to set it somewhere or fix it by the user and especially when it happens, what causes it.
Thank you for answer.
Pavel
EDIT:The problem is in dgnlib if I delete it and copy it again, the problem will be solved.
