I have already saved the file in question with the option remove opencities map specific data. This used to resolve the problem in Bentley Map V8i (Select Series 4) when we needed to merge the file in MicroStation.
I also get the following error message which should not be the case if there is no database connection?
Hello Mariette,
After saving dgn file with option to remove OpenCities Map specific data, you are receiving the error for database connection?
Sanket Butala
Hi Sanket, yes. 0 reference also merged
Thank you confirming, Could you please provide dgn file to check.
