Set of user commands in .dat file that I use in V8i works in OpenCities Map? I tried with no success..
Anybody has successfully set this in a configuration, dgnlib etc?
Hello Satya,
We will need more details. How do you set those file in V8i? Maybe it will need to made little changes inn your path while transaition between V8i and Connect.Maybe you could find any solution by regarding this post? or this article from Wiki ?If not, please give more details about steps, on how you setup this .dat file, variable used, etc. Thank you.
Sebastien Lefrancois
