Does anyone know how fix this? This error came up after I created a project in Geospatial Admin and started populating a file.
Unable to retrieve feature with id: 40bc238a-8bd8-43cd-8b38-16de482e3273
Unable to set properties of an instance based on the following xml: '"Value" is longer than the maximum size of 2<Property><ID>378</ID><MSLINK>1378</MSLINK><PID>0010199.00</PID><STREET></STREET><OWNER></OWNER><MAILING></MAILING><CITY></CITY><STATE></STATE><ZIP></ZIP><TYPE>Value</TYPE><ZONING>Value</ZONING><LEGAL></LEGAL><SUBDIVISION>Value</SUBDIVISION><UTILITIES>Value</UTILITIES><SHUTOFF></SHUTOFF><NOTES></NOTES><Geometry_Area dbProp="true">400.000000</Geometry_Area><Geometry_Perimeter dbProp="true">80.000000</Geometry_Perimeter></Property>'
It appears related to the geometry area/perimeter. If so, how do I change the value to something greater than 2.
Have a look at the details in this article to see if they may help:
https://communities.bentley.com/products/geospatial/desktop/w/geospatial_desktop__wiki/13653/--feature-properties-not-displaying-in-data-browser
Hi James Kramer.
"Value" is the default value used for comboBox Property. Also, when defining a Property in GeoSpatial Administrator, you must set # chars. So, I suppose for one of property TYPE, ZONING, SUBDIVISION or UTILITIES, the default value was set to "Value" and #chars = 2. => '"Value" is longer than the maximum size of 2." I will suggest removing "Value" from initial values section or to set higher number of characters used for those properties.
I hope that helps.Sebastien Lefrancois
Answer Verified By: Dan Weston
I corrected all me features that were set at 2, but the error persist. It appears to be related to the geometry area or perimeter column. But I don't know how to change that. Neither are in my feature list in Geospatial Admin. It is something that is created when I added a polygon.
Sebastien and Dan. You were right. I have corrected my issues and it is now working properly. Thank you!!!
James, you may disable geometric properties (area and perimeter) if this is unwanted in your project. Please see help for more details. Geometric Propertieshttps://docs.bentley.com/LiveContent/web/OpenCities%20Map%20Help-v2.1.1/en/GUID-FEC36B9D-EBB2-9F62-73C5-D118FB6E1FDB.html
Glad to help.
Sebastien
