You might want to fix these small errors in the MapDeveloperShell.bat that comes with the msdk10060106en_updt6.msi.
1) There is one typo that doesn't cause a problem, but apart from that...
2) if for whatever reason you don't want to call the MapDeveloperShell.bat from the delivered shortcut that calls the .bat file with the "--by-guid" option and on the contrary you specify the 3 or 4 arguments (as the usage suggests), then the MapDeveloperShell.bat doesn't work properly. It behaves like you didn't provide the required parameters. It's due to the fact that the opening bracket gets paired with the very first closing bracket and not with the bracket as intended. Please see the picture below:
HTH & best regards,
Mirek Mandl
Mirek,
Thank you for the report. I've confirmed the typographic error as well as the unexpected MapDeveloperShell.bat behavior and have filed a defect to have both issues resolved in an upcoming OpenCities Map SDK update release.
Jeff Bielefeld [Bentley]
