Hello, I need do an export to SHP. Because of error with Czech characters in XFM Properties I changed my Property Parametrs to without Czech characters.
But when I save this strong work with name changed Parametrs and do Save As XML I was very hungry, that after new opening is this Parametrs missing.
I am using BM SS10 because of publishing to Geo Web Publisher.
Thanks for solution suggestions!
shp_export_expx file in txt.txt
Hello Pavel.
By opening your .EXPX file in Map Interoperability, it results to a Missing Feature error (see image below).
By opening the same file in text editor, I see lot of missing part in the code.This is why it fails to read your fail. It seems your file have been corrupted. (see second image below).
For now, I cannot only suggest to rebuild your file. Sorry for the inconvenient.
Sebastien Lefrancois
