Is there a way to edit existing DGN XFM data in a file? I have data that I wish to keep, but some that is no longer needed. Such as, I want to keep city, state, zip, etc... But want to remove NUIDATE, CROSSCONNECT and CCSURVEY.
Basically I want to clean up the data without losing all of it.
Hi James,
James Kramer said:Is there a way to edit existing DGN XFM data in a file?
I agree with Jeff that it can be done (well, when Jeff told it, you can be sure ;-), but I think more details should be discussed to understand a context better.
In my opinion you have to distinguish what is displayed and what is stored:
James Kramer said:But want to remove NUIDATE, CROSSCONNECT and CCSURVEY.
At your screen catpure, these properties are not used, so they likely not stored with an element. But probably because defined as properties of this particular XFM feature, they are displayed in the dialog.
So what "to remove" means to you:
With regards,
Jan
