Marking zones in maps mobile?
Is there a way, in maps mobile, to section off/mark areas as visited? My job involves me visiting man many areas per week and I lose track of where I've been. Im there is a way to mark map sectors that I've visited to help me plan and coordinate my workload more effectively?
I realise I can do this in Google map maker via layers but is there something on bentley mobile that does something similarly?
  • How about creating an Index Map of-sorts in the DGN File before you create the iModel, then use a Redline or Layer control to mark areas/index blocks that have been visited?
    Other options may include using the Saved View selector combined with a Redline - create the Saved Views in the DGN File prior to creating the iModel, then select them to mark off the areas that have been visited.
