Does Opencities Map have support for Inspire GML or it is still possible only using this approach?
https://communities.bentley.com/products/geospatial/desktop/w/geospatial_desktop__wiki/35222/--import-inspire-gml-using-fme-video
Is the Enhancement 677540 still open or is lost due to migrating to CONNECT?
Hi Oto,
Oto said:Does Opencities Map have support for Inspire GML
I think nothing like an official support of Inspire GML datasets exists.
A fact EU represents 2nd (or 3rd, depending on a metrics used) biggest world economy, and INSPIRE has standardized datasets in EU for last 15 years, is not enough to interest Bentley. And it's the reason I see zero usage of OCM on our market (other than as basic drawing tool). I think you will agree with me that you do not support INSPIRE (which is something else than to support GML or WFS that are core base technologies only), you are disqualified in the market automatically.
Oto said:or it is still possible only using this approach?
My experience with GML import in OCM is very contradictory. When it works, it works fine. But it's very basic, not intuitive (better to say user aggressive), and nobody understand rare cryptic warning and messages. To configure anything more than basic import is confusing and exhausting, to fit (map) XFM project and GML import is slow complicated task (GUI is simply basic and bad).
To import GML based on INSPIRE schemas, you have to know (or analyze it in GML file itself), what XSD schemas are used, to download them from INSPIRE web and to find the primary one (experience helps a lot here). When you are lucky, the rest of the process is just "click and import it". And when the import is repeated, it's (finally) simple.
With regards,
Jan
Thanks for input. I have one GML which I would like to try to import. At least in our market INSPIRE for now is mostly used for dataset download but locally thankfully not yet popular but if someone will try to use then I need to be prepared to help.
What about symbology does the INSPIRE GML helps or still need to create it from scratch?
Can you share WFS server address?
Yes it is public.
WMS - https://karte.lad.gov.lv/arcgis/services/lauki/MapServer/WMSServer
WFS - https://karte.lad.gov.lv/arcgis/services/lauku_bloki/MapServer/WFSServer
INSPIRE download - http://proxygds.viss.gov.lv/arcgis/rest/directories/arcgisforinspire/INSPIRE/lauku_bloki_MapServer/serviceatoma1.xml
Online map - https://karte.lad.gov.lv/
Oto said:Yes it is public.
I tried WFS several times, but without success :-(
Using QGIS, I was able to display features, but even in QGIS I have not good feeling. I am not WFS expert, but it just behaves a bit weird (on the other hand, as usually, QGIS is able to connect even to not exactly standard sources).
In OCM, I received the same useless message. I recommend to create Service Ticket specifically for the mentioned WFS servers. Even when it will become clear they are "dirty" (not following standard), OCM has to provide better explanation what is wrong.
Latest QGIS seems is missing some INSPIRE schema. Just noticed one WFS link was wrong now corrected.
Oto said:Latest QGIS seems is missing some INSPIRE schema.
I use 3.8.0, not the latest one ;-)
Oto said:INSPIRE download
I downloaded the file and I was able to open it in QGIS. But it seems not correct, because "fit all" displays a half only. But I am not sure whether it's a problem of GML file (bounding box?) or QGIS.
