Hi, every time I load the map manage I example "gas valve" and then delete it at the next restart of the project I find it again on the project and on the map, I wanted to know if there is a way for the definitive deletion of things on the map manager and if there is also a regenerate drawing command. thanks
Hi Christian,To remove a layer from Map Definition, you can right-click on the layer in Map Manager and select Remove. That won’t delete geometries from the design model.To delete geometries from design model, you can use delete tool from the ribbon home tab. That won’t remove the associate layer from Map Manager.In any time, you can delete Map Definition from the current model. Then you will be able to regenerate then with active features.I will encourage you to read this Map Management chapter from help to distinguish properly these two different concepts. I hope that helps.Sebastien Lefrancois
