I followed the instructions from CONNECT Edition Update 6.
Hi Christian, during the import of a SHP file, first change the color from Bylevel to color number or to RGB values. Next import the SHP file, and features are imported with a color. When you now use the Print Model tool, the Legend Option dialog will appear, e.g. with the example ISO A4 Portrait..
