Hi, in the Printpreout area how do I change the windows in the tamplate without entering the tamplate. Thanks
Hi Christian,
To modify elements in the print template, you must be in the template. In OpenCities Map Connect, you can found tools in Map Admin > Home > Print Templates.
To modify elements in a resulting Print Model, you must be in the model. In OpenCities Map Connect, you can found tools in Map Admin > Home > Print Model. Manipulate and modify drawing tools could also be used in the resulting print model. I will strongly suggest to read Print Preparation section in help to learn more about it. I hope that helps.Sebastien Lefrancois
Answer Verified By: Sebastien Lefrancois
Sebastien, thanks for your answer, maybe I didn't write what I was looking for but I think I have solved it. thanks
I'm glad you resolved it.
