I am trying to load the maps from bing but I have re-identified the problem as shown below, I am asked for the credentials to load the maps, is there any other method that escapes me to load a map?
Hi Christian,
you must have rights (valid key) from Microsoft to be able to use Bing Maps as a raster. You can also set Bing Maps as background Map instead of a raster. Background Map is available in View attributes. See more details in Bing Maps Background Map section.
I hope that helps.
Sebastien
Yes, there is another method - switch to the Background Map process to attach a Bing Map layer. The option is available in the View Attributes dialog box, and offers both Aerial and Street Map types:
Thanks, for the answer I wanted to ask how do I geolocalize the raster? currently I cannot place it on the geolocated project. Thanks
Use Running Coordinates or other method to verify which information is in the correct location, the Background Map or the project. The background map is typically in the proper location so you may have to 'move' the project data.
Dan, currently the project is positioned on the right coordinates I have checked them with the google coorfinates, the raster is not in its position how can I set the raster with the right coordinates?
