I am importing a shapefile of a cadastral map and when importing the symbology does not appear and number,
I would like to know if there is a method to associate the number, found in the attributes of the shapfile, to a symbol of the cadastral map.
Hi. A SHP file does not contain any symbology, it just contains GIS feature instances : geometry and business properties. You will need to use the OpenCities Map features to assign symbology to your feature instances. There are multiple ways ranging from using a schema, assigning symbology at import time or using the thematic symbolization in the Map Manager...
