We have a large number of Oracle Spatial "features" defined (900+). I cannot get Bentley Map or GeoSpatial Administrator to "connect" to the Oracle database. It just "hangs", Using the operability option to establish a "read-only" connection type for importing data works fine, just somewhat slow (due probably to the large number of features). However, trying to establish a "read/write" type of connection, it just sits, and sits, and sits. I've got the 11g client, going to a 10g database. I've tried to "spy" on the SQL being passed to Oracle to see if an Oracle error is occuring and just not being reported, but I can't seem to get a "sensible" trace (it also just "hangs" reporting on the SQL strings.)
Questions: Is there a way to "narrow" the results (ie limit the results to a schema or a set of schemas instead of everything in ALL_SDO_GEOM_METADATA table)?
Is there any way to turn on logging for the Oracle connection part, so I can figure out why the connection "hangs" and never returns any results?
Can we get what version of Bentley Map and the GSA you are using ?
Thanks !
Jerry
Bentley Map/GSA - 8.11.5.49
MicroStation - 8.11.5.17
...to limit the scope of feature classes discovered during the "Register Features" process, use a user account that does not have DBA privileges. For example, using the following privilege assignments...
GRANT DELETE ON MYSCHEMA.MYTABLE TO MYUSER; GRANT INSERT ON MYSCHEMA.MYTABLE TO MYUSER; GRANT SELECT ON MYSCHEMA.MYTABLE TO MYUSER; GRANT UPDATE ON MYSCHEMA.MYTABLE TO MYUSER;
...should allow MYUSER (non DBA privileged account) to access the MYSCHEMA.MYTABLE object during the "Register Features" process.
Jeff Bielefeld [Bentley]
...unfortunately, at this time I don't believe there is a way to restrict the discovery process, but I will do some additional checking to verify that. While we're discussing this topic, how would you as an "Administrator" or "User" prefer to control the feature discovery process (e.g. define the "list" of schemas to be ignored)?
