Hi. I believe it can be a wrong place to ask but admins can move it to the right one. I use Stella Map Finland, it works on a base of Microstation connect edition. I have point clouds in LAS, LAZ formats (ground). Need to make from this point cloud elevation contours, DSM, DEM. I checked videos about Microstation connect, but the was was no way ti use LAS, LAZ formats. Thanks in advance.
With Bentley Descartes (or Open Cities Map Ultimate that includes Descartes) or OpenRoads Designer you can create a terrain model from a pointcloud file. Optionally you can add other sources liker files for breaklines,
