What is the correct procedure to place a subfeature?
Hey Guys!!!
I have a Bentley Map project with a feature text-point (called Id) with its subfeature (a line feature). I don't know how to activate the command place-sub feature, only can activate the command place-feature in the GSA.
What is the correct procedure to place a feature and its subfeature? i'm using Bentley Map SS3.
Thanks!!!
