Placing Text subfeatures - workflow changed
We have some XFM schema files used in Bentley Map V8i, that contains point and line features which have text subfeatures.
In Bentley V8i we could place the root feature and immediately after place the text subfeature in the same operation. In OpenCities Map (update 5 and update 6) the workflow is different, now we have to place the rootfeature and then afterwards edit the root feature, before we can place the text subfeature - why is this workflow changed?
Peter
