I am using a cell made with concrete symbol and cyan color to pattern an area. When I use to to pattern area of a polygon with this cell ends up with color white instead of cell defined color of cyan.
Dropping the cell works with cyan color but I needed it should not be dropped but grouped. Any help is appreciated. Thanks in advance.
- Satya
Thank you Sebastien,
Yes, you are absolutely right, I got it worked on another file. Thank you for your response.
