In OpenCities Map when I'm trying to connect to my database I'm getting the following error:
Exception: An error occurred while parsing EntityName. Line 1, position 214.System.Xml.XmlException: An error occurred while parsing EntityName. Line 1, position 214. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseEntityName() at System.Xml.XmlTextReaderImpl.ParseEntityReference() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace) at System.Xml.XmlLoader.ParsePartialContent(XmlNode parentNode, String innerxmltext, XmlNodeType nt) at System.Xml.XmlElement.set_InnerXml(String value) at Bentley.Geospatial.Utility.SchemaMerger.ExtractECSchema(XmlDocument mergedSchemaDoc, String graphicSourceId) at Bentley.Geospatial.DataInterchange.GeoDataInterchangeAddIn.GetGraphicalSourceSchema(String graphicalSourceKey)
Everyone else in my team can connect fine, we're all using the same workspace. I've tried updating OCM but still getting the same error.
Any help?
Just to clarify, I can connect to the database manually, but I get this error when I use the schema defined database connection
I've tried another workset and i can connect to the defined connection with no problem. So the problem is with the workset, but only for me.
Problem has been fixed. There was a '&' in one of the category names, removed it in Geospatial Administrator and OCM works.
Answer Verified By: Lachlan Hand
what is the database source you connected to ? I reproduce the issue on File GDB. do you use another source ?
I'm connecting to a SQL server
