When attaching a reference file in the dialog box is a option for selecting the attachment level. I want this to always be the default level. What is the configuration variable for this so I can set it in my config file.
Currently I always have to manually set this variable.
Thanks.
Brian, Thank you for reaching out to us. I talked about this option to some colleagues and we should provide you an update soon. Stay tuned.
Sebastien
Brian, the option not yet existing as variable or key-in. Until there, a VBA solution has been provided. You may find details about it on this wiki pageSetting Level for reference attachment (VBA)I hope that helps.Sebastien
