data browser - editing domain list values / dropdown list
hi there,
i have some troubles with editing domain list values with the data browser. editing/setting domain list values with formview (keyboard) ist no problem. if i try to set/edit some values in the data browser, i can't edit or set some other values. additionally the domain list (dropdown list) isn't shown. for example domain list ID_BPLAN_STAND (including 3 possible values):
With the data browser i'm not able to clear or edit the value. the dropdown list isn't shown.
does someone has an answer for this?
thanks and best regards
  • Philipp,  What version of Map are you using, and is the data stored using Oracle Spatial?  If so, there had been reports of this issue, which was corrected in the OpenCities Map CONNECT Edition Update 6, v10.06.00.02.
  • Hi Dan,
    we are using Oracle 12.2.0.1 and the german version of opencities map (10.6.0.5).
    best regards
    Philipp
  • When the cursor is in the (domain list) cell and i'm using the mouse wheel, it crashes / i get an error.
    i don't know if it's the same problem or another one.
    (sorry, cant paste it as an embedded code, because the "paste as code"-function produces an error)
    Informationen über das Aufrufen von JIT-Debuggen
    anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
    ************** Ausnahmetext **************
    System.IndexOutOfRangeException: Der Index war außerhalb des Arraybereichs.
    bei Bentley.UI.Controls.WinForms.TypeEditorControl.SelectStandardValue(Boolean next)
    bei Bentley.UI.Controls.WinForms.TypeEditorControl.OnMouseWheel(MouseEventArgs e)
    bei System.Windows.Forms.Control.WmMouseWheel(Message& m)
    bei System.Windows.Forms.Control.WndProc(Message& m)
    bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Geladene Assemblys **************
    mscorlib
    Assembly-Version: 4.0.0.0.
    Win32-Version: 4.8.4300.0 built by: NET48REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll.
    OpenCitiesMap
    Assembly-Version: 0.0.0.0.
    Win32-Version: 10.06.00.05.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/OpenCitiesMap.exe.
    Bentley.PowerPlatform.FeatureAspects
    Assembly-Version: 1.0.0.0.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Bentley.PowerPlatform.FeatureAspects.DLL.
    System.Drawing
    Win32-Version: 4.8.3761.0 built by: NET48REL1.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
    System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
    OpenCitiesMap.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/de/OpenCitiesMap.resources.DLL.
    ustation
    Win32-Version: 10.14.00.109.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/ustation.DLL.
    Bentley.General.1.0
    Win32-Version: 09.19.02.103.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.General.1.0.DLL.
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
    Bentley.DgnPlatformNET
    Win32-Version: 02.19.02.109.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Bentley.DgnPlatformNET.DLL.
    Bentley.MicroStation.Interfaces.1.0
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.Interfaces.1.0.DLL.
    Microsoft.ApplicationBlocks.ExceptionManagement.1.0
    Win32-Version: 01.00.00.01.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Microsoft.ApplicationBlocks.ExceptionManagement.1.0.DLL.
    Bentley.ECObjects3
    Win32-Version: 09.19.02.109.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.ECObjects3.DLL.
    Bentley.Platform
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.Platform.DLL.
    Bentley.GeometryNET.Common
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Bentley.GeometryNET.Common.DLL.
    Bentley.GeometryNET.Structs
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Bentley.GeometryNET.Structs.DLL.
    System.Core
    Win32-Version: 4.8.4320.0 built by: NET48REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
    Bentley.Exceptions
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.Exceptions.DLL.
    Bentley.logging-2.0
    Assembly-Version: 2.0.0.0.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.logging-2.0.DLL.
    Bentley.Licensing.Client.API
    Win32-Version: 11.00.12.02.
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicService/Bentley.Licensing.Client.API.dll.
    Bentley.Licensing.ServiceInterface
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicService/Bentley.Licensing.ServiceInterface.DLL.
    System.ServiceModel
    Win32-Version: 4.8.4250.0 built by: NET48REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll.
    System.Runtime.Serialization
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll.
    SMDiagnostics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll.
    System.Configuration
    Win32-Version: 4.8.4190.0 built by: NET48REL1LAST_B.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
    System.ServiceModel.Internals
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll.
    Bentley.UI.Vendor.Wpf
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.UI.Vendor.Wpf.DLL.
    PresentationFramework
    Win32-Version: 4.8.4320.0.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll.
    WindowsBase
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll.
    PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll.
    System.Xaml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll.
    PresentationCore.resources
    Win32-Version: 4.7.3190.0 built by: NET472REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationCore.resources/v4.0_4.0.0.0_de_31bf3856ad364e35/PresentationCore.resources.dll.
    Bentley.UI
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.UI.DLL.
    Telerik.Windows.Controls
    Assembly-Version: 2017.2.1717.45.
    Win32-Version: 2017.2.1717.45.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.DLL.
    Bentley.UI.Vendor.Wpf.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/de/Bentley.UI.Vendor.Wpf.resources.DLL.
    Telerik.Windows.Themes.VisualStudio2013
    Assembly-Version: 2017.2.1717.40.
    Win32-Version: 2017.2.1717.40.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Themes.VisualStudio2013.DLL.
    Telerik.Windows.Controls.Input
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.Input.DLL.
    Telerik.Windows.Controls.Navigation
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.Navigation.DLL.
    Telerik.Windows.Data
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Data.DLL.
    Telerik.Windows.Controls.Chart
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.Chart.DLL.
    Telerik.Windows.Controls.Data
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.Data.DLL.
    Telerik.Windows.Controls.Docking
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.Docking.DLL.
    Telerik.Windows.Controls.Expressions
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.Expressions.DLL.
    Telerik.Windows.Controls.FixedDocumentViewers
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.FixedDocumentViewers.DLL.
    Telerik.Windows.Controls.GridView
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.GridView.DLL.
    Telerik.Windows.Controls.ImageEditor
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.ImageEditor.DLL.
    Telerik.Windows.Themes.Office2013
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Themes.Office2013.DLL.
    Telerik.Windows.Controls.RibbonView
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.RibbonView.DLL.
    Telerik.Windows.Controls.RichTextBoxUI
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.RichTextBoxUI.DLL.
    Telerik.Windows.Documents
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Documents.DLL.
    Telerik.Windows.Controls.ScheduleView
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.ScheduleView.DLL.
    Telerik.Windows.Controls.Diagrams
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.Diagrams.DLL.
    Telerik.Windows.Diagrams.Core
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Diagrams.Core.DLL.
    Telerik.Windows.Controls.Diagrams.Extensions
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Controls.Diagrams.Extensions.DLL.
    Telerik.Windows.Documents.Core
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/Telerik.Windows.Documents.Core.DLL.
    Win32-Version: 4.8.4270.0 built by: NET48REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
    Bentley.RibbonView
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.RibbonView.DLL.
    Bentley.MicroStation.Ribbon
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.Ribbon.DLL.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.DLL.
    Bentley.MicroStation.WPF
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.WPF.DLL.
    MdlSeed
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/MdlSeed.DLL.
    Bentley.RibbonView.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.RibbonView.resources.DLL.
    Bentley.MicroStation.Ribbon.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.MicroStation.Ribbon.resources.DLL.
    Bentley.TableUI
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.TableUI.DLL.
    Bentley.TableUI.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.TableUI.resources.DLL.
    Bentley.DrawingScale
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.DrawingScale.DLL.
    Bentley.DrawingScale.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.DrawingScale.resources.DLL.
    Bentley.ECObjects3.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/de/Bentley.ECObjects3.resources.DLL.
    Bentley.ViewGroupList
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.ViewGroupList.DLL.
    Bentley.ViewGroupList.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.ViewGroupList.resources.DLL.
    Bentley.ViewGroupHistory
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.ViewGroupHistory.DLL.
    Bentley.ViewGroupHistory.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.ViewGroupHistory.resources.DLL.
    Bentley.Macros.UI
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.Macros.UI.DLL.
    System.Windows.Interactivity
    Win32-Version: 2.0.20520.0.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/System.Windows.Interactivity.DLL.
    Bentley.Macros
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.Macros.DLL.
    Bentley.Macros.UI.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/de/Bentley.Macros.UI.resources.DLL.
    PresentationFramework-SystemXml
    Win32-Version: 4.8.3761.0.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll.
    Bentley.Geospatial.MapRibbon
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.MapRibbon.DLL.
    Bentley.Geospatial.MapRibbon.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.Geospatial.MapRibbon.resources.DLL.
    mscorlib.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
    Bentley.Geospatial.MapCSUtilities
    Assembly-Version: 10.6.0.5.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.MapCSUtilities.DLL.
    Bentley.Geospatial.Forms
    Assembly-Version: 8.9.99.99.
    Win32-Version: 1.0.0.0.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Forms.DLL.
    Bentley.DialogManager
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.DialogManager.DLL.
    Bentley.MicroStation.MiniToolbar
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.MiniToolbar.DLL.
    Telerik.Windows.Controls.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Telerik/de/Telerik.Windows.Controls.resources.DLL.
    PresentationFramework.Aero2
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll.
    PresentationFramework.resources
    Win32-Version: 4.7.3190.0.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.resources/v4.0_4.0.0.0_de_31bf3856ad364e35/PresentationFramework.resources.dll.
    Bentley.Connect.Client.API
    Win32-Version: 10.00.18.22.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Bentley.Connect.Client.API.DLL.
    Bentley.Connect.Client.Service.Interface
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Bentley.Connect.Client.Service.Interface.DLL.
    Bentley.StartScreen
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.StartScreen.DLL.
    Bentley.Recommendation.API1
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Recommendation.API1.DLL.
    Bentley.StartScreen.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.StartScreen.resources.DLL.
    System.RunTime.Serialization.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Runtime.Serialization.resources.dll.
    WindowsFormsIntegration
    Win32-Version: 4.8.4150.0 built by: NET48REL1LAST_C.
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll.
    UIAutomationTypes
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll.
    UIAutomationProvider
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll.
    MarkupAddIn
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/required/MarkupAddIn.DLL.
    Bentley.DgnDisplayNET
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Bentley.DgnDisplayNET.DLL.
    GeoDataInterchange
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/GeoDataInterchange.DLL.
    Bentley.Interop.MicroStationDGN
    Assembly-Version: 8.0.0.0.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Interop.MicroStationDGN.DLL.
    Bentley.Geospatial.Utility.UI
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Utility.UI.DLL.
    Bentley.EngineeringContent.Storage
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Storage.DLL.
    ODF
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ODF.DLL.
    Bentley.Geospatial.Base
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Base.DLL.
    Bentley.Ogc.Base
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Ogc.Base.DLL.
    Bentley.Geospatial.Utility.ECObjects
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Utility.ECObjects.DLL.
    Bentley.Ogc.Style
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Ogc.Style.DLL.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Utility.DLL.
    Bentley.EngineeringContent.Utility.UI
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Utility.UI.DLL.
    Bentley.MicroStation.WinForms.ECPropertyPane
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.WinForms.ECPropertyPane.DLL.
    Bentley.EngineeringContent.SelectionCriteria
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.SelectionCriteria.DLL.
    Bentley.Ogc.Geometry
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Ogc.Geometry.DLL.
    Bentley.Geospatial.DataInterchange.DgnFileIOBridge
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.DataInterchange.DgnFileIOBridge.DLL.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Utility.DLL.
    Bentley.Geospatial.SpatialReferenceSystems
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.SpatialReferenceSystems.DLL.
    Bentley.Ogc.SpatialReferenceSystems
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Ogc.SpatialReferenceSystems.DLL.
    OgrStorage
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/OgrStorage.DLL.
    GmlStorage
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/GmlStorage.DLL.
    Bentley.EngineeringContent.Storage.Oracle
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Storage.Oracle.DLL.
    Bentley.EngineeringContent.Storage.ObjectToRelationalStorage
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Storage.ObjectToRelationalStorage.DLL.
    Bentley.EngineeringContent.Geometry
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Geometry.DLL.
    Bentley.EngineeringContent.Storage.SqlServer
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Storage.SqlServer.DLL.
    Bentley.EngineeringContent.Storage.Postgis
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Storage.Postgis.DLL.
    ArcGISStorage
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ArcGISStorage.DLL.
    eBECStorage
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/eBECStorage.DLL.
    WfsStorage
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/WfsStorage.DLL.
    Bentley.EngineeringContent.Storage.EsriFileGeodatabase
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Storage.EsriFileGeodatabase.DLL.
    Bentley.EngineeringContent.Storage.Xfm
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Storage.Xfm.DLL.
    Bentley.Geospatial.SpatialReferenceSystems.MicroStationGCS
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.SpatialReferenceSystems.MicroStationGCS.DLL.
    Bentley.GeoCoord2
    Win32-Version: 03.19.02.109.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Bentley.GeoCoord2.DLL.
    GeoDataInterchange.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/GeoDataInterchange.resources.DLL.
    Bentley.DgnGeoCoord2
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Bentley.DgnGeoCoord2.DLL.
    Bentley.MicroStation.Templates
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.Templates.DLL.
    Bentley.MicroStation.Templates.Support
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.Templates.Support.DLL.
    Bentley.MicroStation.WinForms.Controls
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.WinForms.Controls.DLL.
    Bentley.MicroStation.MaterialControl
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.MaterialControl.DLL.
    Bentley.TerrainModel.ElementTemplate
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.TerrainModel.ElementTemplate.DLL.
    TerrainModelHandlerApp
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/TerrainModelHandlerApp.DLL.
    Bentley.ExpressionEvaluator
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.ExpressionEvaluator.DLL.
    Bentley.TerrainModelNET.Element
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.TerrainModelNET.Element.DLL.
    Bentley.ECSystem3
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.ECSystem3.DLL.
    Bentley.EC.AbstractUI3
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.EC.AbstractUI3.DLL.
    Bentley.Visualization.TypeEditors
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.Visualization.TypeEditors.DLL.
    ConnectAdvisor
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/required/ConnectAdvisor.DLL.
    Bentley.RSS.Interop
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.RSS.Interop.DLL.
    Bentley.MessageCenter
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/required/Bentley.MessageCenter.DLL.
    Bentley.Connect.Advisor.Api
    Win32-Version: 10.01.00.245.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/ConnectAdvisor/Bentley.Connect.Advisor.Api.dll.
    ConnectAdvisor.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/required/de/ConnectAdvisor.resources.DLL.
    Bentley.DesignlinksApp
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.DesignLinksApp.DLL.
    Bentley.Connect.Advisor.ApiFactory
    Win32-Version: 10.01.00.270.
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.ApiFactory.dll.
    Bentley.Connect.Advisor.Logging
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.Logging.DLL.
    log4net
    Assembly-Version: 1.2.15.0.
    Win32-Version: 1.2.15.0.
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/log4net.DLL.
    Bentley.EC.Controls3
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.EC.Controls3.DLL.
    Bentley.ExtensionDiscovery
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.ExtensionDiscovery.DLL.
    Bentley.EC.Persistence3
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/BENTLEY.EC.PERSISTENCE3.DLL.
    System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll.
    Bentley.EC.Presentation3
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/BENTLEY.EC.PRESENTATION3.DLL.
    Bentley.ECStorageECPlugin
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/BENTLEY.ECSTORAGEECPLUGIN.DLL.
    Bentley.Geospatial.Framework
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Framework.DLL.
    Bentley.Connect.Advisor.OopWrapper
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.OopWrapper.dll.
    Bentley.FmeECPlugin
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/BENTLEY.FMEECPLUGIN.DLL.
    Bentley.Connect.Advisor.Api2
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.Api2.DLL.
    Bentley.Connect.Advisor.ServiceContract
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.ServiceContract.DLL.
    Bentley.MicroStation.ECIntegration
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/BENTLEY.MICROSTATION.ECINTEGRATION.DLL.
    Bentley.RuleDrivenPresentationECPlugin
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/extensions/Bentley.RuleDrivenPresentationECPlugin.DLL.
    Bentley.RuleDrivenPresentationECPlugin.PresentationRules
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/extensions/Bentley.RuleDrivenPresentationECPlugin.PresentationRules.DLL.
    Bentley.DgnECPlugin3
    Win32-Version: 04.19.02.109.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/extensions/Bentley.DgnECPlugin3.DLL.
    Bentley.Geospatial.Support
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Support.DLL.
    CivilEH
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/CivilEH.DLL.
    PrintPrep
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/PrintPreparation/bin/PrintPrep.dll.
    Bentley.DataExchange.FmeExtension
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.DataExchange.FmeExtension.DLL.
    CifDWGExportManager
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/CifDWGExportManager.DLL.
    Bentley.StatusCursorPrompt
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.StatusCursorPrompt.DLL.
    Bentley.MicroStation.CursorPrompt
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.CursorPrompt.DLL.
    Bentley.Geospatial.MapCSUtilities.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.Geospatial.MapCSUtilities.resources.DLL.
    Bentley.Geospatial.Explorer
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Explorer.DLL.
    bentley.geospatial.core
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/bentley.geospatial.core.DLL.
    Bentley.Interop.Xft
    Win32-Version: 2.0.0.0.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Interop.Xft.DLL.
    Bentley.Geospatial.NetDialogLib
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.Geospatial.NetDialogLib.DLL.
    Bentley.Windowing
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.Windowing.DLL.
    GDIExplorer
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/GDIExplorer.DLL.
    Bentley.Geospatial.Nodes
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Nodes.DLL.
    Bentley.CustomControls.UIExtension
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.CustomControls.UIExtension.DLL.
    Bentley.Geospatial.Utility.UI.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.Geospatial.Utility.UI.resources.DLL.
    Bentley.Geospatial.AnalysisMixed
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.AnalysisMixed.DLL.
    MapQuery
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/MapQuery.DLL.
    Bentley.Ris
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Ris.DLL.
    Bentley.EngineeringContent.Schema
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Schema.DLL.
    Newtonsoft.Json
    Assembly-Version: 7.0.0.0.
    Win32-Version: 7.0.1.18622.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Newtonsoft.Json.DLL.
    Bentley.Geospatial.Ris
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Ris.DLL.
    MapManagerApp
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/MapManagerApp.DLL.
    Bentley.Geospatial.MapManager.Core
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.MapManager.Core.DLL.
    Bentley.Geospatial.Maps.MapManager.XFM
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Maps.MapManager.XFM.DLL.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Maps.MapManager.DLL.
    Bentley.Geospatial.ECObjects.Maps
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.ECObjects.Maps.DLL.
    Bentley.Geospatial.ECObjects.Style
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.ECObjects.Style.DLL.
    Bentley.Geospatial.ECObjects.SpatialReferenceSystems
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.ECObjects.SpatialReferenceSystems.DLL.
    Bentley.Geospatial.ECObjects.Base
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.ECObjects.Base.DLL.
    Bentley.Ogc.Maps
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Ogc.Maps.DLL.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Maps.DLL.
    Bentley.ECObjects.Extensions.Utility
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.ECObjects.Extensions.Utility.DLL.
    Bentley.Geospatial.Maps.MapManager.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/Bentley.Geospatial.Maps.MapManager.resources.DLL.
    Bentley.Geospatial.Style
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.Style.DLL.
    Bentley.Geospatial.MapJoin.Core
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.MapJoin.Core.DLL.
    Bentley.NavigationEventListener.Managed
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.NavigationEventListener.Managed.DLL.
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.MapJoin.DLL.
    Bentley.Geospatial.MapUI
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.MapUI.DLL.
    DgnDisplayUI2
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/DgnDisplayUI2.DLL.
    Bentley.ECObjects.MixedMode3
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/Bentley.ECObjects.MixedMode3.DLL.
    Bentley.PropertyManager
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.PropertyManager.DLL.
    PrintprepInterop
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/PrintPreparation/bin/PrintPrepInterop.dll.
    Bentley.Geospatial.DataInterchange.XmlFragmentIO
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.DataInterchange.XmlFragmentIO.DLL.
    Bentley.MicroStation.WinForms.Docking
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.WinForms.Docking.DLL.
    Bentley.Windowing.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/de/Bentley.Windowing.resources.DLL.
    Bentley.ECUISupport
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/bentley.ecuisupport.DLL.
    Bentley.ECBrowserDgnIntegration
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/extensions/Bentley.ECBrowserDgnIntegration.DLL.
    Bentley.RasterProperties
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.RasterProperties.DLL.
    GoogleEarth
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/GoogleEarth.DLL.
    Bentley.PointCloud
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/bentley.pointcloud.DLL.
    publishdgn
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/publishdgn.DLL.
    Bentley.MultiPointPlacementManager
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.MultiPointPlacementManager.DLL.
    Bentley.NamedPresentation
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.NamedPresentation.DLL.
    Bentley.CustomProperties
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.CustomProperties.DLL.
    Bentley.MicroStation.WPF.Controls
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.MicroStation.WPF.Controls.DLL.
    Bentley.QuickInfo
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.QuickInfo.DLL.
    Bentley.ECReporting
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/mdlsys/asneeded/Bentley.ECReporting.DLL.
    Bentley.EC.Controls3.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/de/Bentley.EC.Controls3.resources.DLL.
    DgnDisplayCSUI2
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/DgnDisplayCSUI2.DLL.
    DgnDisplayCSUI2.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/de/DgnDisplayCSUI2.resources.DLL.
    Anonymously Hosted DynamicMethods Assembly
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll.
    PresentationFramework-SystemData
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll.
    System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll.
    Bentley.ViewAttributesDialog
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.ViewAttributesDialog.DLL.
    GDIExplorer.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/GDIExplorer.resources.DLL.
    Bentley.Geospatial.MapFeatureTracking
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.MapFeatureTracking.DLL.
    Bentley.EngineeringContent.Gml
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Gml.DLL.
    Bentley.EngineeringContent.Gml.Schemas
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Gml.Schemas.DLL.
    ODF.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/ODF.resources.DLL.
    Bentley.EngineeringContent.Storage.Oracle.Support
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Storage.Oracle.Support.DLL.
    Bentley.Geospatial.SpatialReferenceSystems.Oracle10R2
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.SpatialReferenceSystems.Oracle10R2.DLL.
    Bentley.Geospatial.GeometryConvert
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.Geospatial.GeometryConvert.DLL.
    System.Design
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll.
    MapQuery.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/de/MapQuery.resources.DLL.
    Bentley.EngineeringContent.Storage.Oracle.TopologyInfo
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.EngineeringContent.Storage.Oracle.TopologyInfo.DLL.
    Bentley.EC.Presentation3.resources
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/ECFramework/de/Bentley.EC.Presentation3.resources.DLL.
    System.Windows.Forms.resources
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
    Microsoft.GeneratedCode
    Bentley.CGOgcConversion
    CodeBase: file:///C:/Program%20Files/Bentley/Map%20CONNECT%20Edition/OpenCitiesMap/Assemblies/Bentley.CGOgcConversion.DLL.
    ************** JIT-Debuggen **************
    Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
    Konfigurationsdatei der Anwendung oder des Computers
    (machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
    Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
    Zum Beispiel:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
    Ausnahmen an den JIT-Debugger gesendet, der auf dem
    Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
    best regards
    Philipp
