Attribute sort order when I register database features
Hi all!
I have a problem that could be solved previously but I didn't found any solution. If there is a solution please forward it to me.
I've created database table with fields (attributes) in particular order. Same attribute with same order I've created in GSA. When I register database features in GSA they change my original order and offers me to sort by attribure name or display name. Both are not good for me.
My question: Is there a chance to register features without changing my original sort order or how to manually change order after I register features?
Main problem is display order in Analyze form. Place and edit forms with attributes are ok.
Many thanks in advance.
Mladen
Map-GSA V8iSS4, db: SQL Server
