Using OpenCities Map Advanced. Downloaded county-wide spatial and tabular soil survey data from the USDA NRCS Web Soil Survey. The tabular data is in *.mdb format. How do I pull the *.mdb file data into the dgn map to associate it with the spatial data?
I do not use these databases, but I should probably learn how. If there are any Bentley resources on learning to use these with Map, please send the info my way.
The Working with Spatial Databases chapter in the Map Help document is a good place to start. The full versions of Oracle and Microsoft SQL Server can be expensive, but they offer low-cost alternatives (SQL Express). PostGIS and File Geodatabases are free.
Following up on next steps of this joining of spatial and tabular data...
After joining the data, I'm trying to export it as a shapefile. However there is some kind of problem with the feature/column names.
For example, the name of the tabular data file I joined to the shapefile is "muaggatt.csv". Each column in that csv file is named "Column1", "Column2", and so on. When joined to the spatial data, the new column names become "muaggatt.Column1", "muaggatt.Column2", and so on. When I try to export this as a shapefile, I get an error message that says "Error: Duplicate property name: muaggatt_C.
We've seen that duplicate property name issue before. The .dbf file has a limitation on the number of characters allowed, so you have to edit the properties to make them unique. Right-click on the Feature name in the Export dialog, select Show Properties > Ungrouped, and rename one of the duplicates to be unique to the 9th character.
