Good morning and happy Friday.
I hope someone out there can tell me how to get a topo file that was generated with OpenRoads Survey exported to a ESRI shape file or is this even possible?
Gerald Piotrowski
OpenCities Map Advanced contains the function to export to Esri's SHP file format.
Answer Verified By: Gerald Piotrowski
Is there a documented workflow for this?
In addition to the instruction Kees suggested, there is a short Communities article called Export to ESRI Shapefile format.
And from the Map HELP file, the GDI key-in examples are available for review:
