how to define MS_GUIDGNLIBLIST variable to point to a dgnlib file in GSA?
I've tried all combinations (or maybe not) but adding value to variable works only if I do it manually in OpenCities Map.
Soon you have edited the variable directly in OpenCities Map Connect, it will set the variable to User level. The variable defined in GeoSpatial Administrator is defined at WorkSet level. As it is explained here, User level is the highest priority level.To remove User level tag, select MS_GUIDGNLIBLIST in Configuration Variables dialog and click on Delete button. Close the file and re-open it to see MS_GUIDGNLIBLIST back to WorkSet level as defined in GSA. For more details about Configuration Concepts, please read the detailed definitions from help page.
I hope that helps.Sebastien
