[OCM U16] GSA workspace path
We recently upgraded to OpenCities Map Upd. 16, and in has a challenge with GSA. When we export our XFM setup from GSA, the Workspace is written to C:\ProgramData\Bentley\Map CONNECT Edition\MapAdvanced\Configuration\WorkSpaces and not the path that given in GSA as it did before - why is that.
I have attacehed an example XFM project, where the Workspace should be written to F:\Appl\BentleyConnect\Workspaces, but ends up on C:\ProgramData\Bentle..........................SurvCap_Stofa.xml
  • Hi Sebastian
    When we install OpenCities map we can’t set path for the delivered configuration. The dialog from your answer shown below, simply don’t show up during installation:
    Med venlig hilsen
    Peter Norvin
    Chefkonsulent, landinspektør
    Mobil +45 4018 7068
    pen@geopartner.dk
    Bredhøjvej 5, 2. sal
    8600 Silkeborg
    CVR 20014784
    Geopartner Landinspektører A/S' ydelser leveres i henhold til vores forretningsbetingelser
    og i overensstemmelse med vores persondatapolitik
    Fra: Sebastien.Lefrancois <bounce-80680C15-CFCB-4CED-B4EF-6EF422F9E3E7@communities.bentley.com>
    Sendt: 8. oktober 2021 17:37
    Til: OpenCitiesMap@communities.bentley.com
    Emne: RE: [OpenCities Map Forum] [OCM U16] GSA workspace path
    ok. i do not reproduce the issue on my side.
    I am sure you done that, but on installation be sure to set appropriate path for the delivered configuration.
    If the issue still persist, maybe uninstall/re-install the application, followed by a reboot of your machine.
    I do not get what is happening. This is why I am shooting everywhere.
    Sorry for the inconvenient.
    Sebastien
    View online
    You received this notification because you subscribed to the forum.  To unsubscribe from only this thread, go here.
    Flag this post as spam/abuse.
    Denne e-mail er blevet scannet for at stoppe evt. spam og virus. Hvis du mener, at denne besked burde have blevet stoppet, skal du klikke her for at rapportere beskeden som spam.
    Answer Verified By: Peter Norvin
  • Hi Peter,
    During installation, at the first page on the right top there is a button Configuration to open the Configuration settings.
