Hello guys, there is a big possibility that you will redirect me to different forum with this kind of question, but here i am.
Basically I have a .shp file containing contours generated by GDAL, and I´m importing it into OpenCities with keyins:
gdi import storage[storage] options gdi open name=[storage] file=[pathToShp]
In old V8I, after I imported the created elements i could see the feature properties in "Element information" window immediately. However, after using the CONNECT edition, I have to restart the entire application(OpenCities Map Advanced Update 7) to see the feature properties.
Before the restart it looks like this(properties are not visible even in Show/Hide menu):
After the restart (yes different feature name)
However, even though these properties are not visible at the start, I can access them via the VBA and its PropertyHandler. Do i need to call some UI event to see these data immediately? Thanks for help
Edit1: I don´t know if it helps, but the newly added elements also do not display any of the items attached to them (see the picture of how it should look)
The newly added elements contain only Linestring without any items. After i close and open the app again, the Items are displayed correctly.
Hi Lubo,
I guess you should move your question to OpenCities Map forum, because it is not MicroStation and it is also not programming question (you use standard key-in, not API).
To move existing discussion to another forum, use More > Move tool, available under your original post.
With regards,
Jan
Unfortunately, I was able to reproduce the behavior you observed and I submitted your case to development team.
If you could provide you shapefile for investigation. That will be helpful.
Thank you again for reporting. Sorry for the inconvenient.
Lubo B said:However, even though these properties are not visible at the start, I can access them via the VBA and its PropertyHandler. Do i need to call some UI event to see these data immediately? Thanks for help
We are not aware of the event to call. File > Open would be the workaround.
Best regards,
Sebastien
