Is it possible to use Map without XFM schema?
Map crashes if trying to create new Workspace and Workset from file open dialog.
Even selecting Examples->Metrostation workset program doesn't open and crash.
Is it only for me or everyone else?
Hi Oto - did you find a solution/workaround for the issue ? we are experiencing similar behavior.
FYI - our issue occurred because of the change in ENGINENAME. “OpenCitiesMap” to “MapAdvanced”.
