iTwin Authorized Product Change Report
I have a simple question. I use 2 products.
Map PowerView Connect Edition (Update 16) and Microstation Connect Edition (Update 16).
I will open any DGN drawing in Microstation Connect Edition. Then I open the same DGN drawing in Map PowerView Connect Edition and this message appears.
In translation:
The current DGN is authorized by MicroStation for iTwin purposes. Do you want to change the authorized product to MapPowerView?
I did not knowingly set up any sync, authorization or iTwin.
I wanted to ask how to get rid of it, or how to set it so that the message doesn't appear to me.
Thank you.
Pavel
Parents Reply Children
