multiple lines Annotation not working as supposed
with OpenCities Map Advanced Update 16 we have issues with multiple line annotations that are created from one attribute.
For example there is an xfm attribute INFO with the value "1st line \010 2nd line \010 third" it creates following annotation:
In Bentley Map the 2nd line was "2nd line", now all new lines starting with a number are cut in that way (spaces in front of the number won't solve that issue).
Is it a bug and do you have any hints on how to use \010 as new Line in current versions? The annotation is created by a usual PBA expression like [INFO].
Kind Regards,
Maik
Parents Reply Children
