Have an issue with Bing maps & Opencities Map Advanced. I have a DGN file which has Bing Maps raster attached. I can bring this file up in V8i and Bing Maps displays with no issue. However, when I open this file in Opencities Map Advanced, the raster will not display until I perform an update. Is there a setting in Opencities that I have failed to address?
Hi Larry,
Is the Bing Maps raster attached in the Raster Manager dialog? If so, turn that off and turn on the Bing Maps Background Map option in the View Attributes dialog.
Answer Verified By: Dan Weston
That's the ticket!! Thanks Dan!
Glad to help. Let us know if you have additional questions.
