WorkSet Not found Alert
I work in an environment where my dgn files move from 2 different groups with different worksets. Every time when I use DGN file from other than my workset environment I get "WorkSet not found alert"
I know there is batch run key in commands available to set active workspace and workset but is there any way that I can apply my active WorkSpace/WorkSet without popoup message by autorun on 'opendesignfile'  procedure. I tried some options nothing works out as this dialog box pops up way before open the design file.
Appreciate any help.
Thank you in advance.
Parents Reply Children
