Does anybody know if dgn2sdo.exe (part of Bentley Map v8i SS10) will be available under OpenCities Map Connect?
regards,
Sjoerd
You might want to move your post to a more appropriate forum where users those packages will be better suited to answer your question.
Hi All, See reply from Dan Weston of duplicate post : communities.bentley.com/.../dgn2sdo-exe
Answer Verified By: Sebastien.Lefrancois
