I keep getting pop up message saying "Connect to database" even though there is no database connected to it.
I tried all the options like disconnect , detach database linkage etc. nothing works. Please help. Thanks
Kindly share the version of MicroStation
Are you autoloading any of the DB tools via configuration variables MS_INITAPPS, MS_DGNAPPS?
Check/Share the workspace logs
Show Configuration
MSDEBUG
Thank you Leonard Jones. My version : OpenCities Map Ultimate CONNECT edition update 7 - Version 10.07.00.62
I do have autoloads configured for MS_DGNAPPS.
"PrintPrep.ma;Bentley.DataExchange.FmeExtension.dll;$(MS_DESCARTESDIR)mdlapps\DcStmCore.ma;CifDWGExportManager;Bentley.StatusCursorPrompt;dcartes;Bentley.Geospatial.MapCSUtilities.dll;bentleymap"
please note that I get 'connnect to database' pop up for only few dgns.
Satya Gundabina said:I keep getting pop up message saying "Connect to database" even though there is no database connected. OpenCities Map Ultimate CONNECT edition update 7
I see that you already found the OpenCities Forum. I suggest that you move this post to that Forum as well. Use the More=>Move button.
There's a Wiki for that:https://communities.bentley.com/products/geospatial/desktop/w/geospatial_desktop__wiki/47359/--disable-connect-to-database-dialog
Set this variable, exit, and reinitialize:MS_GEOXFM_DISALLOW_INFERRED_DBCONNECTION = 1
Let us know if that works.
Thank you Dan Weston. It worked. Nice.
My follow up question is, when there are no linkages or connection to database is established , why this message pops up?
In future if I have to connect to a database, looks like I need to set this value to none again? Thank you.
