Good day, we have custom linetypes and for liners that use the "Standard solid line" or "Linetype 0" linetype, the lineweight does not appear in the OpenCities Map PowerView version. The Bentley Power Map version works fine.
Did anyone solve the same thing?
Hi Tomas,
I see the line weight for custom linestyle on my side. Is Line Weights have been disabled in View Attributes?If View Attributes settings do not resolve the issue, could you provide DGN library file or/and Resource file used for the custom line style ? Regards,Sebastien
Hi Sebastien,
when I have "Line Styles" deactivated, the thickness is displayed correctly, but when I activate them, the lines are displayed with a thickness of 0 for the specified line types, even if they have a different thickness in the attributes. When I select a line, the highlight shows that the line is thicker, but the display is incorrect.
When I open the same drawing in Bentley Map PowerView V8i SS10, the display is correct.
Best regards,
Tomas
Thomas, ok. I see the issue in your screen capture. But I am still not reproduce on my side. we will tried to narrow down the issue.Are you using custom workspace in Map? or no workspace/no workset ?Verify those variables are properly defined: MS_DGNLIBLIST_LINESTYLES and MS_SYMBRSRC.If MS_DGNLIBLIST_LINESTYLES variable is not defined, then the DGN library files will be taken from the MS_DGNLIBLIST configuration variable. If you could share the .rsc file used to defined the line style. I may be able to compare parameters with mine a found the culprit. Because for now, I do not see why it works on my side and not on your side. I am continuing investigations. I hope found a culprit of this behavior. Or a workaround. More to come. Sebastien
Hi Thomas,I finally reproduce the issue on CONNECT Edition.This issue only occur on specific settings. I reported to the internal instances for evaluation (#867797).As workaround, in Line Style editor, you can set stroke dash full width to correspond to the weight values.
Sorry for the inconvenient.
Regards,Sebastien
I don't have the MS_DGNLIBLIST_LINESTYLES variable configured. I added specific libraries within MS_SYMBRSRC, but the problem didn't work out.
