Good day, we have custom linetypes and for liners that use the "Standard solid line" or "Linetype 0" linetype, the lineweight does not appear in the OpenCities Map PowerView version. The Bentley Power Map version works fine.
Did anyone solve the same thing?
Hi Sebastien,
thank you for your time. We use CONNECT edition.
Specifically for this type of line, I cannot change your proposed parameters.
I may try to send a line library.
Tomas
