I'm unable to link a reference to a drawing.
Hello, I am Saurabh from Inco Special Alloys.
I can press the connect reference button, but nothing happens. It works when I try to create new files, but only when the file is open. It doesn't work if I close it again. Thank you for your assistance.
  • Hello Saurabh,
    I am not sure I follow your workflow. Not sure to understand what the problem is exactly. I will try to narrow down you issue by developing your steps.
    Ok. That is annoying. It should works. It works on my side.
    ok. So, something wrong in your actual file. No more issue in new file.
    Wait. which file you talked about ? Ok. I am confuse. So, staring from here, we have the master drawing and the reference. We want to attach reference file to the master drawing file.First, you have to open the master file. So, if that file is closed, the reference process cannot occurs. But the reference file not need to be open to be able to reference them. Is what you said ?
    So, my understanding is you can only attach reference file to the master file when the reference file was already open in another session. Right?
    Using term as connect and links causing confusion about which area of the applications you talked about. I will need more details to have a better understanding. For now, the attachment process work fine on my side. Please provide master and reference file to be able to reproduce the issue on my side.
    More specific steps and files could help to narrow down the issue.
    Please read the Attaching Reference section to have a better understanding of the process.
    https://docs.bentley.com/LiveContent/web/OpenCities%20Map%20Help-v14/en/GUID-EABC903D-462D-3A3F-A742-00EB5B720A5F.html
    Thank you.
    Sebastien
    This is a test
