Hi Everyone,
I converted a revit model through using i-twin platform, the schema generated in the i-model manager i want to take the schema generated and insert it in open cities map.
anyone can help how to conduct this process ?
Hi Amr,
Amr Ashraf said:the schema generated in the i-model manager
I am not sure whether I understand your question right: What do you mean by "schema generated"?
Do you mean BIS, created and encapsulted in iModel to describe used data structures?
Amr Ashraf said:insert it in open cities map.
I am not sure about OpenCities products, but in MicroStation, it is possible to attach iModel from iModelHub in the similar way as other references.
With regards,
Jan
