Hi All!
When I open a desing file in Open Cities Map Powerview Update 16 the following dialog pops up.
"Active configuration (WorkSpace/WorkSet) does not include the latest changes to its associated schema.
Do you want to update the configuration?"
Is it possible to hide this warning?
If I can not hide it, how can I create a config file that is valid for U16 after a clean install? (clean install means that I copy the workspace/workset config files to the install dir and open the dgn)
It is offered by the program to update the config file automatically. I accepted the automatic update.
Under "<map powerview install dir>\Configuration\WorkSpaces\" I have a <worksapce name>.cfg that changed and a <worksapce name>.inc file is created. A schema file is also created in <install dir>\Configuration\WorkSpaces\Map_Schemas\<schema name>.xml.
I tired to use the updated/created filesbut the same dialog popped up.
Br,
Miklos
Here you can find the dialog...
Hi Miklos, I've asked the Map team to get back to you on this one.
Marc
Hello Miklos,
Beginning with OpenCities Map Update 16 the configuration (Workspace/Workset) needs to know if you are working with a Map Schema or not.
You can work in OpenCities Map without any schema by using No Workspace/No WorkSet.
You can work in OpenCities Map by using a Workspace/Workset from MicroStation. Those do not require an OpenCities Map schema.
All Map configurations (Workspace/WorkSet) require a schema. If one does not exist, the software will ask the to user to localize them.
There are some additional alerts and settings that will help in this area
Another Configuration Warning:
and a Preferences setting for non-Map Workspaces:
Thanks Marc!
Hi Dan!Thanks for the clarification. I got the above warning and chose 'Yes'.After that the automatic config update changed my config file so that there is the following include in the config file:#========================================================================================# Include GeoSpatial Administrator generated configuration data#========================================================================================%include mir6.incIn the above include file there are the following lines:#----------------------------------------------------------------------------------------# Path to GSA schema.#----------------------------------------------------------------------------------------MS_GEOXFM_SRC_SCHEMA : C:\BentleyCE\MapPowerView\Configuration\WorkSpaces\Map_Schemas\mir6.xmlTo my understanding my workspace/workset (mir6) includes a schema. However the warning still appears.If I set the above preference the warning disappears.Is there a configuration varible that is equivalent with the above preference?Br,Miklos
