Hi All!
When I open a desing file in Open Cities Map Powerview Update 16 the following dialog pops up.
"Active configuration (WorkSpace/WorkSet) does not include the latest changes to its associated schema.
Do you want to update the configuration?"
Is it possible to hide this warning?
If I can not hide it, how can I create a config file that is valid for U16 after a clean install? (clean install means that I copy the workspace/workset config files to the install dir and open the dgn)
It is offered by the program to update the config file automatically. I accepted the automatic update.
Under "<map powerview install dir>\Configuration\WorkSpaces\" I have a <worksapce name>.cfg that changed and a <worksapce name>.inc file is created. A schema file is also created in <install dir>\Configuration\WorkSpaces\Map_Schemas\<schema name>.xml.
I tired to use the updated/created filesbut the same dialog popped up.
Br,
Miklos
No configuration variable. User Preferences only.
This is how such alert looks on 4K display. We need it to be gone.
Yes. Very annoying.Thanks Oto. We reported to the development team.I am sure you know the workaround until we fix it; you can reduce the window scale and text size to avoid the problem.
Sorry for the inconvenience.Warmly,Sebastien
Sebastien Lefrancois said:you can reduce the window scale and text size to avoid the problem.
Can't. Changing DPI settings it becomes blurry.
