I am in the process of customizing the new datum and Ellipsoid based on our company standards, the method is Grid shift files Nadcon format which is .las and .los files. Can any one guide me in OpenCities Map how to write or in what way the software will accept while defining in Edit Datum Properties. Please see the attached snapshot for more clarification.
Ilyas
With the NADCON grid file format you do not list both las and los files but simply indicate the extension to be 'l*s' so you file should be C:/CustomGCS/AGD21.l*s
Thanks Robert for your quick reply, I will check and confirm.
I am always getting the below message
At least one grid shift file is missing or of an incorrect format for the new Geographic Coordinate System. If you continue reprojection may be incorrect or imprecise. Otherwise Cancel and install the files in the correct location under the path indicated in the MS_GEOCOORDINATE_DATA environment variable.List of files: C:/CustomGCS/AGD21.l*s
I am really sorry about my mistake. The documentation is lacking and I will make sure it is corrected. I was mistaken with the name to indicate. Instead of the * character you need to use the question mark character instead (?). So file name specified should be C:/CustomGCS/AGD21.L?S instead. I verified before answering this time. Sorry again.
