I want to connect to an external PostGIS database in OpenCitiesMap, but I always get the following error message: authentication method not supported (received: 10). By the way, with ArcGIS I can connect to the PostGIS database without any problems.I use OpenCities Map Advanced Connect Edition Update 7 (10.07.01.09)How can I solve the problem?
This was corrected and is available in a later version. Please update to Map CONNECT Update 16 or Update 17 and try the connection again. Please file a Service Request if the problem persists.
OpenCities Map: Software Downloads (bentley.com)
Answer Verified By: Sebastien Lefrancois
you are right. Thanks.
