Is there a way to export dgn elements to shapefile using VBA? I did not find one in help files. Appreciate any inputs to start with. thanks in advance.
I use OpenCities Map ultimate connect edition update 16.
I always use keyins Gdi Export for the SHP export, see https://docs.bentley.com/LiveContent/web/OpenCities%20Map%20Help-v14/en/GUID-E51EEA9E-EC80-455D-9466-4126E04D6DD5.html.E.g. in a VBA add elements to an selection set and in the VAB send the keyin Gdi Export Selection=True
Answer Verified By: Satya Gundabina
