Good morning, I disappeared the command manger window and I can no longer activate it, I also entered the command "activate readonlymethod" but to no avail. help me Thank you
Hi Christian,the complete command to open command manager is Key-in: activate readonlymethod MainMenu2|Openyou can also use another command to close the Key-in: activate readonlymethod MainMenu2|CloseIn Connect edition, you can also place feature from a list in the ribbon: Ribbon > Map > Home > FeaturesIf undocked, you can also retrieve command manager dialog in window list from the ribbon:Ribbon > Map > Primary > More > Window List
If issue persist, I will suggest removing a file from cache. Please, close application and remove Personal_dlgprefs.xml file from C:\Users\[]user.name\AppData\Local\Bentley\[Map.Edition.Name]\10.0.0\prefsRestart the application. I hope that helps.Regards,Sebastien
Answer Verified By: Sebastien Lefrancois
A thousand thanks
